Help with shift drum alignment
How should the shifter drum be aligned when putting the case back together on a 07' cr125? There is an alignment notch on the end of the drum but no mark to line it up with. Thanks.
On my 01 cr250 that little pin sticking out will be used to align the drum shifter. It will become more clear to you when you begin to assemble the shifter mechanism after the half's are together.
