Triple clamp issues
I bought a used set of procircuit triple clamps off ebay the other day which look in good condition but after fitting them to the bike the front wheel looks about 3-4° too much to the right, Anyone seen this before? could the triple clamps be damaged or bent? I fitted them and seen the fault then dissasembled everything and double checked and re-fitted and still got the problem :s
The front mud guard seems fine with the handlebars it looks as if the front wheel is out which has got me thinking one of the clamps could be bent and causing the forks to be in diffenent angles and twisting the wheel but I cant see anything obvious thats causing it. Any ideas or suggestions guys?
Did you loosen the axle bolts and compress the forks several times? Are the spacers installed correctly?
Yea done all that twice, and still no joy :s
