kx 85 2006 full rebuild wont start?
Hi
i just picked up a kx 85 2006 with full rebuild today then i started it let it idle then turned the choke on then it cut out and now wont start any help?
You probably fouled your plug. Don't turn the choke on when it's running only when you start it, if need be.
Exactly, the choke is for the initial fire then shut it off and keep the bike running easy till warm enough to ride. But not to say something didn't go catastrophically wrong internally. (worst case scenario)
Big question...Who built it??? If it's internal, which is a very good possibility, it could be a number of things. But before you get really worried about an internal catastrophe, triple check all wiring, kill switch (disconnect wires from killswitch) check coil, stator and CDI connections (Check for SPARK!!!)
After you check all external things (fuel, spark, etc) report back and we'll continue with any other possibilities.:thumbsup:
Hi
We havnt even rode it properly or broken it in yet it was just starting up when we brought it home but I cleaned the plug sanded it took all the black stuff off and still nothing we bought its from blacks bike shop in burscough industrial estate
Thanks
Hi sorry I was ment to put the choke was on then I turned it off then it wouldn't start
Thanks
Compression (how much)? Spark?
Just rebuilt dirty plug?
Hi how do you test compression? I think it's fine more than my cr80 and how do you test the spark? Do ou just take it out and kick it over?
Ohh and yeah there was abit of fuel on the plug when I took it out but it was dark couldn't tell that much
Yippie!!!!!! Just got her started I read on a post similar to the to hold the throttle open and kick and she started first time, any ideas why it wasn't starting thanks you for the help , any ideas why?
If it started when held open it was flooded.
AND...it's a 2 stroke. not one of them-thar thumpety things. WOT starting...WOT riding. Pin it to Win it.:thumbsup::ride:
