1991 kawasaki bayou 300
we have had this machine since new. Just recently it started idling rough an seems to erradically backfire through the carb. there is also a slight knocking noise occasionally from the crankcase. neither of which are cosistent. It runs normal at higher rpm. anyone have any ideas? Thanx
After cleaning ensure you have a new spark plug and remove the old gas and put in new. With the new fuels today (ethanol) you can end up with water in your tank very easily if left for extended periods.
