Mikuni 26 carb jetting for a 143 klx bigbore
I have a 143 big bore with
a mikuni 26 carb on it
main jet is a short hex 125
pilot is a really small 3/8 long 15
external filter
middle clip position (don't know the needle #)
tell me what yours is and i'll double check
bike bogs just of idle big time then catches back up and
runs good on the middle and topend
plug is showing rich (black)
wondering if these two jets are even the right types for this carb
I thought mikuni 26's had round mains & longer pilots
if anybody could please post some pictures
of the right jets that would be great
(I can't get pictures to post on thumpertalk, sorry)
help :thumbsup:
oakley37 in nebraska
1100 ft
Does the carb bolt directly to the intake manifold, or does it slide into a rubber boot and held in place with a hose clamp?
It it looks like the carb pictured below, it is:
A. A Mikuni-clone carb that is only 22mm.
B. A baseline setting to work from for that carb is:
1.#100 or #105 main jet
2. #17.5 pilot jet
3. jet needle clip in the 3rd or 4th position from the top
4. fuel screw 1-3/4 turns OUT from seated.
C. Because it is a fuel screw, to lean it, you have to turn the screw IN.
If it looks like the carb pictured below, it is:
A. The Mikuni VM26-606 spigot mount
B. The stock jetting for that carb out of the box is:
1. #190 main jet
2. #22.5 pilot jet
Here is a pic of the jets the two carbs use...
thanks for the pictures
The carb looks very much like the
Mikuni VM26-606
and the jets match the pictures
you have for this carb
So that kinda puts me at ease
(right carb, right type of jets)
But I'm way off on the main
I have a 125 in there right now!!!
can this be possible, runs pretty good from
mid-range and to the top
bogs bad off the bottom???
and what should the fuel screw be set at
for a starting point for this carb
Thanks very much 188
From what I've read in some of the other pitbike forums, most guys with the VM26-606 are using a 155 to 165 main jet (they are available in increments of 5), and I'd have to double-check to see what the recommended pilot jet is.
As far as the baseline setting for the air screw, try putting it at 1-1/2 turns out from seated, to start. Make your turns in 1/4-turn increments, IN to richen the mixture, and OUT to lean it.
I would try going up to a 17.5 or 20 on the pilot jet, for starters, to clear up the low end hesitation from being too lean in the idle/1/4 throttle area.
