engine oil drain bolt location - 2006
I realize this is a stupid question but where is the engine oil drain bolt located on a 2006 CRF450R?
On ther, newer CRF's that I have owned the engine oil drain bolt was located on the bottom of the case. I could not see a bolt on the bottom of teh 06 case so I am guessing it is on the side somewhere (similar to the trans oil drain bolt).
Thanks in advance.
The engine oil drain bolt is on the left side (i.e. drive line side) and is the bolt at the bottom of the engine case cover below the shifter knob. The transmission oil drain bolt is to the right of the engine oil drain bolt, below the front sprocket.
Your service/owners manual should have pictures of it.
