2006 TE450 Electrical Issues
Hi guys,
I just had a new stator put in at the dealer. My bike started running great again. Now this weekend, the battery is dead and the instrument cluster wont stay on and the headlight just barely glows. I hooked up a battery charger to aid the battery and the problem stayed. I cleaned up any terminals that I could get my hands on and still no change. I'm going to get a new battery, but I don't think that it is my problem.
While riding some times the horn would work and some times nothing. Am I looking at a rectifier or ??????????????
BTW. Kicking these beasts over all day SUX.
Thanks,
Conte
It sounds like it's a bad battery. The horn thing is another issue... check connections and see if you have a worn wire. Actually check all the wires especially where they are zipped tied to the frame or in a tight place. You might have something draining the battery. But I've had simular problems and the battery was the problem.
