08 250 exc speedo
Hi i was hoping someone can help me with my speedo. Its not showing the speed although it is lighting up but just turns off again after a minute or two.
I've put a new battery in it and checked that the magnet is there on the disk and all the wires are running to the caliper.
Was hoping there might be an easy fix for this.
Thanks Stephen
If the speedo does not turn on automatically when you roll the front wheel, then your speed sensor assembly is bad. It happened to my 05 EXC. Everything "appeared" to be there, but I replaced the speed sensor bolt/wire thing and it corrected the issue. I could see no damage to the old one, but it was the problem.
Got a new cable. It turned out that the connector at the clock was plugged into the wrong one, this must have been done by the last owner.
Think i'll be leaving the new cable back, they're not cheap at £34.
Steve
