06 250 Clutch Issue
My clutch had very little "slip" when i pull away from standstill , i have to let the lever out a fair way before it starts to bite ,then it only needed to be let it out a small bit more and it was fully engaged , so i brought new friction and steel plates and it's still the same , the cluctch basket had a few ridges on it so i filed them off , but its still exactley the same , not alot of feel at all .... any help appreceated thanks ...
The slip area is very small on these bikes, stiffer springs helps a bit.
It does work pretty good once you get used to the feel for one finger clutching, since all the slip is out at the end.
