proposals to soften comp. stack
Shock KYB YZ 85 small wheel, a-kit with sep.nut
Kid is 35 kg without gear
midpack mx
current stack
34x0,2(5pcs)
32x0,2
32x0,2
30x0,2
28x0,25
26x0,30
24x0,30
22x0,30
20x0,30
it seems overly stiff for his speed/style and i would like to soften the overall feel (bike is sprung for his weight)
here is the stock stack to compare
34x0,15 (6pcs)
28x0,10
18x0,10
34x0,20
32x0,20
30x0,25
28x0,25
25x0,25
23x0,25
21x0,25
20x0,30
18x0,20
Thanks in advance
Kim
34x0,20
32x0,20
34x0.20 (3)
32x0,20
30x0,20
28x0,25
26x0,25
24x0,25
22x0,25
20x0,30
i will try this,a little soft
34x0,20
32x0,20
34x0.20 (3)
32x0,20
30x0,20
28x0,25
26x0,25
24x0,25
22x0,25
20x0,30
Just put it together with
34x,2
32x,2
34x,2(3pcs)
24x,2
20x,2
32x,2
30x,2
28x,25
26x,30
24x,30
22x,30
20x,30
ill mount it tomorrow to get to feel the diff
Thanks
Kim
have you tried the stock stack?
Yes ,coming from an allmost stock stack (stock shock)
and the difference is huge
i would like it a bit stiffer than stock, but not like this
just bought complete suspension from a faster/bigger kid
complete Kyb a-kit forks in the right color:smirk: (dark brown and dlc)
and 2 shocks
The forks work very good but the shocks are to stiff
it could be that starting out with the stock stack is a better startingpoint for us
Is that what you suggest?
thank
Kim
Why have u done ?
34
32
34x3
suggested by cardinale199
and i have to learn by try/error as im new to this shuffling
Kim
With a STD stack it will feel harder with the rebound separator valve.
34
32
34
I don't think u will achieve anything like this u need to put 32 under the 34s. Was u trying to use the 34 as a bleed shim. It won't achieve much over 32
34
32
34
I see what you meen with the separator nut
i will put the other shock together with stock stack for testing
thanks
Kim
34 32 34 is a single stage for mx on crf 250 44 44 42 44 44 44 44 44 44 44 44 30.15
Ill let you know how it feels on the bike
Kim
i didnt put 34 -24 -20 it s a big crossover!at this time you havnt,it s big difference the low speed of shock is more soft then you are riding today
i saw a similar thing done somewhere else and put it in there myself
i knew i needed to do something more and just wanted to try it, maybe it will mess it up ??
Kim
i make more revalving for having the best for my rider,you can t find the best at the first,you must be very lucky to have it!!!i make a little change at time,for not loss the way if you are not expert,but try ther's nothing wrong
one 20,020 crossover make less difference ls-hs than 24-20 with 2 cross the bike go down at rear more easly than today on bump and push on hs stack
i see it ,it was wrong to try two different things at once
what i thought i did was to soften the stack in both low and high speed
and yes im a complete novice when it comes to suspension tuning:lol:
the season is ending and we have plenty of time to try different things
thanks again
Kim
got the 2 shocks together
the one with the stock comp.stack feels much like the stocker even with the separator nut ,i will leave it like this and we will see how it is on the track
the other shock
34x,2
32x,2
34x,2(3pcs)
24x,2
20x,2
32x,2
30x,2
28x,25
26x,30
24x,30
22x,30
20x,30
feels softer now but still not near the stocker
this is two very different setups and he can get to try both one day at the track and we will see what he says
If i want to stiffen the stock stack a bit overall , what would be my startingpoint
all help is much appreciatred
Kim
Remove the 18 clamp shim and it will stiffen the entire stack a bit.
34x0,15 (6pcs) 34x0,15 (9 pcs) 34x0,15 (7pcs)
28x0,10 28x0,10 28x0,10
18x0,10 18x0,10 18x0,10
34x0,20 34x0,20 34x0,30
32x0,20 32x0,20 32x0,30
30x0,25 30x0,25 30x0,30
28x0,25 28x0,25 28x0,25
25x0,25 25x0,25 25x0,25
23x0,25 23x0,25 23x0,25
21x0,25 21x0,25 21x0,25
20x0,30 20x0,30 20x0,30
18x0,20 18x0,20 18x0,20
the first is stock. the second is stiff at low speed and a few on high speed and the last is stiff on hs and a little on ls.i ve used less xover for fast rider.any comment from others?
