Oil Question...NOT AN OIL THREAD
I have a 2009 DRZ 400sm with 200 miles on it. First oil change recommendation is 600 miles, but I am changing it early. I have just received the TT Oil Change Kit, question is, should I use synthetic now at only 200 miles, or go back with a mineral oil and change to synthetic at the 600 change?
Thanks in advance for any input.
Not an expert by any means...but I believe basically you don't want to break you new engine in on synthetic, and most of the break in is within the first 20-50 miles or so. In my not so professional opinion, you should be good to go. Make sure you go ahead and change the filter too, which is in the kit, along with the washers. Don't reuse them.
Always lots of opinions here.....For a brand new engine I would stay with mineral for the 1st 600 miles...and then go to semi or full syn, depending on your riding conditions...
For General use on a stock engine, semi is adequate and for a stroker , racing use or riding in extreme conditions go with Full syn...
