front fork leaks
i have a small leak on one of my front forks....couple drops every other day,,,,,its a 1991 cr 125........is it hard to fix that?? should i just fill it back up every now and then?? im not very mechanical, how would i check the level....any help would be great,,,,thanks
when were the fork seals changed last? i believe theres a quick fix using 35mm film, but if its been leaking a while then theres a chance that the oil level in each fork is varies from one another...best solution...look into new fork seals and an oil change
just bought it last month and just noticed the leak the other day.....how hard is it to gange seals and is there a way to tell if the level is different?? like i said im learnin as im goin
