Ride Bike Height - 09 250sxf
What is this measurement (in mm) for this bike and how is it measured?
Byte
Byte
If you are talking about front and rear 'sag' settings, they are listed in the service manual.
A rule of thumb is 15/35% of max travel for static and race sag in the front, and 25mm/100mm of static and race sag in the rear. Spring changes are needed if you weigh other than 165 lbs.
That is the general rule of thumb for linkage bikes. The KTM's with PDS require more race sag then a linkage bike.
Thanks guys.
I was not referring to sag settings, but just straight out stock height from stock to ground, and stock ground clearance.
Byte
