TE250 2010 cant go pass 60-65 mph.
Hi.
i installed the power surge on the bike and it feels like its going slower.
gearing is 13-50.
when i used stock map i remeber going over 80-85 mph.
any one else....?
Hi.
gearing is 13-50.
any one else....?
Then you need to adjust it. What is your setup? Bike and mods? I'm guessing you need to run the red zone up some if your not getting enough top end. Feel free to experiment. I have one on my Te511 and mounted it to my bars until I sorted out what my bike liked. I found it real simple to find some good settings. The Husky are almost always lean, if you have a trouble spot try going richer, sometime a lot richer and see what happens. Also mounting it to your bars indicates where in the throttle and map you are and then you will know what parameter to change. Good luck.
right now im on the recommanded settings.
i tried playing with it but i cant seem to find the spot.
i need to go back to the stock (OEM) mapping and feel the diffrence.
