05 crf450r idel and starting problems
05 crf450r tokyo mod carb, fmf 4 pwr core mega bomb header
my bike is a ***** to start cold it will fire up then die, or just not kik over at all and have to push down a hill and dropp into second gear to get going, once running i cant get the right mix of a good idle and no popping on decell. iv messed with the idle and fuel mix for a few days now with no luck, once its good and warmed up it runs fine except for popping on decell i keep increasing the fuel mix and it dosnt go away, any ideas?
clogged pilot jet possibly.. when you remove it, remember that not just the 8 tiny holes on the side of the jet need to be open, but also the tiny hole right down teh middle.. don't ask me how i know about that now .. LOL.
Also, take a few moments and pull the valve cover off and check your valve clearances.
I will definetly check the pilot jet but i just got the carb back from tokyomods and installed it and had this problem.
adjust the idle
clean the pilot
make sure the hotstart is not stuck in the carb open and there is slack in the cable
inspect the valve clearances
Make sure you dont have an intake leak somewhere from the installation!
