EXC 125 won't start
Help! Bike was running fine then died. It sat for two days, started right up, then died while running, now won't start.
Kicks like it's got good compression. Bad fuel? Clean carb? Suggestions?
Well there are a whole lot of things to check. Pulling the carb apart for a cleaning and inspection is a good start. Pull your reed cage out for inspection. Pull and clean or replace your spark plug.
Joe........
Check your fuel first but if it did start up then wouldnt restart Id go more with joe with the plug first. is your filter clean? Make sure your getting fire, you should get at least a 13mm to ground. I usually check fuel (make sure its clean then remove 14mm drain plug from bot of carb and make sure there's good flow, then fire to the plug) and go from there.
