2011 crf 450 BAD BOG
I have a 2011 crf450 and its got a bad bog at the crack of the throttle..had in the shop they claimed the fuel injection was bad..after that, the problem was still there..they also said that it was the yosh exhuast and the pmi 2 box..which doesnt make any sense..any help would be greatly appreciated thanks.
Sounds like it could be a TPS issue or adjustment. Does it ride ok? Clear up above part throttle? What are all the issues you're having?
Well from close to about quarter with a quick snap it bogs really bad. it runs really well its jsut the throttle response the thing only has 6 hours if that..its got full yosh system and the pmi 2 box.. its done it from day 1
mine did that bone stock until I sent my ECM out to Eddie Sisneros.
No more bog
No more flame out
Yeah the ECM is key. Getting that done should help.
Also, EFI bikes (in my experience, no scientific data to back this up) must be completely warm before they run correctly, so make sure your bike is at operating temperature.
Just had the same problem with my 11 CRF450. I was at the track and ran it out of gas, from then after I had a bog. I changed out the fuel filter inside the tank and the bog went away. I'm not sure if that was it or there was a air bubble in the system. But whatever it was, it seem to fix it. It really sucks when jumping and the bike doesn't respond the way tou want. Good luck!
