crf250 2011 stock shim stack?
does anybody have the stock rear shock shim stack for the Honda CRF250 2011? I would like to compare it to the new 2012. I heard the rear is 5mm lower. Did the whole linkage change like for the 450, or just the pull rods length? Thanks
shock comp
stk
3 - 44.25
9 - 44.2
37.15
23.15
44.25
42.25
40.25
38.25
36.25
34.25
32.25
30.25
28.25
26.25
24.25
23.3 b
6 - 25.6
shock reb
stk
3 - 40.2
26.1
40.3
38.3
36.3
34.3
32.3
30.3
28.3
26.3b
the rebound is way stiffer, and that can be ok, but the compression is way softer, and it doesn't look good to me
yes ,the stock reb is light for my thinking.the bike swinging much and kick up on jump.but any rider like the bike with fast reb on hole.depending how fast you are and if you like the reb in other part of track
it also has a poor transition from low to high speed damping, which tends to drop it into the stroke. i like to go up on the x-over. the reb is also weak for sure.
