03 YZ 85 running to rich? Need Help
Ok, so my bike is smoking alot more than usual it fowls the plug every time i start it, I mixed it 32:1 with 91 octane gas. But it is still smoking any suggestions?
Pull the carb and see what jets it has in it and where the needle clip is. Check these results to the stock results in a factory service manual.
Put the stock jetting and needle clip back in.
Clean your air filter and re oil it.
Put a new spark plug in it.
If that doesn't cure it up some, there may be more going on. Like a leaking crank seal, top end way past it's service life, etc.
