nipples and spoke
I have a big problem with my tires. i want to fix them because the are off balance.
the nipples is corroded to the spoke and if I try to tighten them they turn together. What is a best way to fixs them other than changing them?
Time for new spokes. No cheap way to properly fix it. If you try and hold the spoke with pliers, you'll damage them which will weaken them. Buy stainless steel spokes and take better care of them. Use anti-seize on the threads and check after every ride.
