ICO checkmate Enduro computer battery
Anyone on here replace there battery in the checkmate enduro computer. Or do u always send it in.
i was thinking the a battery store may be able to change it even though it says to send it back to ICO to have the battery replaced.
Any thoughts?
I had a friend try to open it up and replace the battery on his roached out Checkmate. Didn't work and he ruined it. He sent it in and they told him it was unreplaceable.
If you try it, proceed with caution.
Yes you can change the battery. You must keep the unit powered while changing the battery with jumpers to the new battery. Ico has a code that must be used to turn the computer back on after a battery change. ICO will not give out the code, that is why you must keep the unit powered during the battery change.. Also if you send it in for a repair after you have changed the battery they will rape you for the repair charges. The replacement battery is under $20.00 from a battery store. You must dig out the potting material from around the old battery and seal the new battery in potting material.
so if the battery is dead then u will most likely need the code to restart it?
my checkmate has been sitting for three years so it is very dead.
thanks for the info.
