03 problem. Backfire.
I've got an 03 with an FMF, stock header, loud mouth intake, and recently done the ap mod. I got rid of the bog when you hammer it but now I've got a nasty backfire on decel. I cleaned all the jets before doing the mod. Could this be a jetting problem that can be fixed with a JD kit? Thanks guys.
If you took the throttle slide plate out you might have put it back in upside down or the pilot jet might be clogged.
1 1/2 is stock. So I have it there. So try 2 1/2??? Does turning it out make the mixture richer???
Btw my leak jet is 90 for the ap mod.
Yes going out is richer. But i would check for an exhaust leak first , and a clogged pilot jet , that your best bet.
