2002 DR650 cutting out
I have read through the threads but can't seem to get the bike running right.
Every 100 Km or so the bike starts to cut out as if the kill switch is turned off and on quickly during about 60 Km/hr, but when I pull over it will idle OK.
The kick stand switch is off and the clutch leads are disabled under the headlight.
I thought it was the fuel at first so I cleaned the carb, checked the float and replaced the jet and needle. Still doing it. I then took it to the dealer and they said that everything seems OK and tuned the carb for me.
It now does it lees but every now and then it cuts out when driving.
Could it be the CDI or coil on the way out? I'm out of ideas, thanks for any help.............Todd
