radiator fluid?
hi guys
what ration and what radiator fluid are you guys running
mines in need of a change
I run Engine Ice, be warned you must COMPLETELY FLUSH your cooling system of ALL old coolant before installing engine ice or it WILL gum up your water pump.
That being said this is what I do;
Drain coolant
Run 1/2 gallon of water through open radiator
Install waterpump drain
Fill radiators with distilled water
Run bike for 2-3 minutes
Drain water
Fill with Engine Ice
Ride!
Let me know if you have any questions
Andrew
CB5 Racing
hi guys
This works well. Don't run any car fluid. It will eat seals. The Honda stuff will not.
08C50-C321S01_is?$product_large_1000$
the liquid performance orange stuff is great. you can flush it with tap water. as long as you dont run it with tap water.
