patella femoral syndrome questions
I have been dealing with this for almost 3 years now. The first doctor to look at me never said the words patella femoral syndrome but what he did do is tell me to speed walk for 3 months and all will be ok. 3 years later I can still hear some of the crunching.... not nearly as bad but there is some there. I stopped motocross for the last 3 years because of fear that I will make it worse. Plus life got in the way and took my mind off motocross.
So now I want to return to my local track in the spring and I want to be healthy. Went to a new sports med doctor and he said patella femoral syndrome. Told me I had a imbalance in my leg muscles and set me up to do physio and also highly suggested that I look into Yoga.
Now, will fixing the imbalance and stretching do the trick for me by spring? I have a hard time with that because I have taken it easy on my knees for 3 years and the problem is still there. Granted the terrible crunching when I walk up and down stairs has lessened by 80% but will me knees be able to take a season of motocross twice a week? I am 41 btw.
The left knee is the worst. I can feel my knee cap hang up on something ever so slightly when I extend my leg then it will pop free. I can't get it to do it all the time, once it has done it it wont happen again until I let my leg rest for a min. Also, I tried an exercise where to balance on the one leg and with the other to reach it out to 12 o'clock position, bring it back to center then go to 1 o'clock, bring it back the 3 and so on. When I do this I can hear my left knee making crunching sounds each time.
Is this actually going to go away if I strengthen my leg muscles and stretch properly?
Patellafemoral syndrome is medicalese for you have a bad knee cap and I don't know what exactly is wrong.
Acess to specialist care is rather limited where you are and I wish I could give your more advice, but without seeing you, getting weight bearing X-rays, and a CT scan, I couldn't do better than patella femoral syndrome, myself.
The CT scan is only of value if the doc know what to look for. If all you can get from them to date is patellafemoral syndrome, I doubt a CT would help in your current situation.
