exhaust
hi guys, ive just bought a new front pipe for my 06 wr250. The pipe has an air valve fitted and what looks like a catylitic convertor. Im thinking of just blanking off the stub outlet and removing the catylist??
Any ideas, the exhaust is brand new off an 08 I think
I have fitted new red/white plastics, head light, all cables, discs, new led rear light, headlight, powdercoated frame, acewell digi speedo etc.. bike is as new.
Looking for graphics, seat cover, any suggestions, looking to spend around £120
Hello bud what you have is the stock factory restricted pipe, even if you cut the pipe open and remove the cat the washer and everything else the bike will never run right. i've been there and tried it.
Gnarly pipe and will probably have to re jet, the factory graphics look good, I just put the Polisport tank covers on with the embedded graphics. Guts makes covers as well as some others, I have a new cover in the shop, i'll have a look and let you know who makes it.
An after market is a good idea too, the stock tip is a little smooth.
thanks for the replies, looking at removing the cat from the standard pipe, is it just a case of hammer and chisel job or will the pipe have to be split??
thanks
