tapered steering bearing problem
So I've got a set of taper bearings in my KLX that won't tighten up properly. I can crank down on the nut as hard as I can but there's still significant play forward and backwards when you hold the front brake and push on the bars. These are brand new bearings. Any tips on getting them to seat properly?
make sure the bottom race is all the way up as far as it can go. Same with the top one.
there is usually a set for the bottom and a set for the top. Make sure you have the right ones in.
