PN for lower 1st gear into a '99 KX250
freds40 it takes the input shaft and the matching gear on the output shaft from a 94-98 KX 250, I have gotten around 10 of off ebay in the last 5 years by buying whole transmissions cheap when they came up. Here is a thread I did years ago and wasn't good with pics so you have to click on them to see them http://www.thumpertalk.com/forum/showthread.php?t=582009&highlight= In the parts dia you have it is the shaft 13127-1227 and gear 13129-1160.
Also I have put in the 91-94 KDX 250 trans in mine too http://www.thumpertalk.com/forum/showthread.php?t=1002545&highlight=
Ask more if you need.
Ed
I saw your full trans. swap and that is pretty appealing, just figured I'd do the "easy" fix for 1st.
I really should go the route of the complete trans ass I can easily whip up the sleeves you mentioned and the ratios sound awesome. I'll have to put some more thought into this.
It really is easiest to buy a complete used tranny. Did this to a 2002 KX250. Worked out very well.
