2011 steel clutch basket vs. flywheel weight.
Well, I want a heavier flywheel for my 11' but I can't find anyone that makes them. So... Do the steel baskets do as advertised? Can they give me that flywheel effect despite being on a different shaft than the actual flywheel?
It will not give you the effects of a heavier flywheel.
The clutch spins at 1/3 the crank speed and also in the opposite direction.
It will of course add some weight, but it will not behave anywhere near as a heavy flywheel does.
Call Steahly and see what is up.
D-k is correct, the clutch basket will not give you the same effect.
and a steel basket will go through trans bearings waaaaaaaaaaaay quicker
