stuck in 2nd gear
my 01 300 mxc got stuck in 2nd gear what should i check first.any thoughts on what the problem is. bike was running great previous day.thanks
you have ashifter tumbler I had one and the same thing came up, its a I think 8mm allen head key bolt, tighten it up to spec. lock tight it! you have to remove the clutch cover, remove oil, and antifreeze, new gaskets too. Do it right, or do it again.
thats what it was. that allen head bolt was loose already took care of it thanks.
