looking to put a mechanical speedometer on xr 400
hi i have a 2001 xr 400 i just got and its all set up and is regestered as a dual sport but i need a speedometer i dont like the idea of the electric ones i would like to replace my odometer with a speedometer/odometer im wondering if anyone has done this. i was looking at my friends xr 650L and the speedometer looks like it might work but im not really sure. if anyone has any ideas please let me know thanks!
I have Trail Tech units on both bikes and never had a problem with either one. The endurance or vector models are cheap and super easy to hook up. Just curious as to why you don't want to go that route?
I put the Baja designs analog mechanical speedo on my 98 xr400. holding up well. great customer service. back lit so you can see it at night. Plugs right into the odometer cable.
easy.
They all use the same speedo cable, so any Honda speedo will work. I have the ATK speedo (love it) and prefer it over my electronic ones as well (Vapor and Endurence)
I agree with Michigan, what's wrong w/ electric? I've had 2 Trailtech's and they both worked flawlessly. Plus they offer a wealth of additional information: run hours, engine temp, ambient temp, tripometer, odometer, avg speed, max speed, current speed, rpm, even gps.
Just because I not want to have to worry about breaking it off or tearing the wiring idk just not want I would really trust ... But it is good to hear that they work for you thanks for the imput !
Thank you all for the imput ! Such great help ! I'm glad to know both are good routs I'm going to price them out and see what works best and I'll post up what I have found. Thank you all so much !!
Just because I not want to have to worry about breaking it off or tearing the wiring...
The spedo cable hangs out ALOT farther then the small wire on the trail tech, which is zip tied to your front brake cable. Just saying.
I've heard of WAY more Trailtechs breaking in the past 5 years than I've ever heard (in 50 years) of mechanical speedos breaking. :busted:
Several guys here are on their 3 or 4th trailtech. :busted:
easy.
I am looking at the same thing for my 91 DR250M. I have headlight/tail-light/odometer...I noticed the Baja Designs is universal and is lighted, I just don't know where/how to plug it in to get it to light...I have never done anything to my current bike but want to now make it street legal so that I can ride to my riding areas instead of trailering it. Any advice?
Thanks
I put a mechanical speedo on my KLX. I used an xl600 one. worked well and cable bolted right up. Later broke the speedo and put on another cheapie fom ebay ($10.00). I think it came off a kawi this time.
You can cross species if that helps your quest. Just look for a bike that had a 21 Inch wheel.
I made a bracket and installed a speedo from an old Yamaha XT225 on my bike. (looks just like the ATK unit, as likely is) The cable from the odomoter plugged right into it. Only problem, is it only lasted a month or so and died... and I just went back to the odo. The electric trailtech would probably be easier to mount and more durable.
If you go mechanical, make sure you use a speedo off a bike with a 21" front tire so it will be accurate.
Good Luck!
Edited by n2omike
