Coolant question
2011. Bike losing about 6 to 8 oz. coolant after two hour race. I can't find any leaks. Bike has cv4 hoses. Thank for any help.:busted:
look at the pages on this subject my bike was losing coolant and i could not find a leak either evidently when running the weep hole on the water pump lets the water go straight down to the ground and you never see the water, pressure check your cooling system,the water usually only goes out when running hard and i made a over flow using my frame it also could be going out your overflow too
