Athena BB and Yoshimura TRC removal issues?
Hi all,
Removing my Yosh Ti seems very hard to do.
It will take forever and loads of zen.
The part where you wiggle the midpipe through the frame/cylinder is just too tight.
The athena seems just a bit bigger on the outside compared to OEM.
I cannot seem to remove the Muffler from the midpipe, is that what i'm doing wrong?
Anyone have tricks?
Thanks, J.
no real ricks.
just twist the mid pipe until it fits.loosening the stay on the subframe helps also.and check with suspension spring for clearance.
muffler should be off mid pipe when doing this.
Thanks.
I will try harder to get the thing off.
That must be the problem.
