float height
i know theres threads on this but anyway..
can someone do me a HUGE favor and post a pic of how the flaots are supposed to look? i dont have the measure tool and cant measure the correct height
im pretty sure im way out of adjustment mainly because there is fuel pooring out of the over flow :busted:
i might just go ahead and order replacement parts.. if i do so, will this be all back to correct height? (new float,needle valve set,float pin)
If gas is pouring out of the overflow chances are your float is stuck open. Take a screwdriver and use the plastic handle and tap against the float bowl to see if it will drop down. It should unless it is really really stuck then you have to take it apart.
