CaveMike need know suspension/chassis differences from 2002-2007
CaveMike pondering cr250 project. What differences there be in suspension from 2002-2007. What year changes happen? CaveMike hear 2001 and newer motor actually work better than later motor.
Hmmm him want project, need him hunt skpn8r's cr250 project bike. New frame old motor.
Cavemike want only best cr250 with no hammer much with tool clubs, then want 05-07 with jd jetted pwk air striker carb conversion.
Frame and Suspension him want only 02+
05+ forks lugs brought back 5mm closer to frame, many caveman like.
what's cavemike doing in the Honda forum!?
there is a sticky by faded about the year to year changes for the cr250 in the forum.
The 02 CR Showa forks have a smaller compression piston valve & shims than the 03+ forks. You already know 05 legs have -5mm offset... But if you already run 22mm clamps & the -5mm forks can be too much IMO...
