how to get a dint out
honestly is it possible? to get a dint out of your head pipe?
ive tried the water in the pipe and freeze it and nothing changed?
any ideas?
cheers
block off both ends of ur pipe . put a small hole in one end for air compressor nossile. and then use air comp until dents out ... good luck
the water freeze didn't work the first time for me but when i made sure there were no air bubbles and taped the ends real good it started to work. after the first freeze i ran the dented area under hot water and re froze and the dent came out perfectly. not sure it will work everytime but might be worth a try.
Mine was smashed pretty bad and I ended up using 40 lbs of air pressure and heating the the dented areas with a torch to get them to pop out. Just make sure the plugs are good and tight and not pointed at anything or anyone when you start applying pressure and keep the flame moving.
The first time I tried putting air in mine the plug blew out at about 30 lbs. It sounded like a cannon. Scared the hell out of my neighbor.
Good luck and be careful...
