Baja Designs HID kit
I got the B.D light just over a year now works really good will say the d.c conversion is lame you have to jump a wire on the stator and there is
NO freeking room to work (crimp) http://www.thumpertalk.com/forum/images/smilies/foul.gifplus cutting and splicing on the outside wires not really fun cutting on factory wiers soooooo. If I did it again KTM HID, PLUG AND PLAY=NO HASSLE costs more but its clean and a no brainer install just my opinion. 530 exc 2010
:busted:
Do you have a link or something? I can't find anything on KTM's web site.
looks like a nice light- but just buy the trail tech stator upgrade. the stock system of ac and dc is nuts. the stock system barely works. If you add a fan or bigger light you will kill the battery if your rpm are low when riding.
discofever daveg got it right that is what I have. got the stator from ktm dealer, turns out trail tech makes it for ktm. ktm also has hid its the x2. I am very happy with the bd hid light and the trail tech stator sorry bout the confusion
What the hell is the rectifier? Is that changing the electrical from A/C to D/C?
And I have no clue about the newer one's coming stock DC:excuseme:
A rectifier turns the ac current from you alternator to dc voltage. Battery voltage=dc house power =ac.
if you turn your key on- and you head light comes on with you motor off, It dc. If it only come on when you start the motor it is ac.
The reason behind jump a wire on the stator is to combine both outputs together so that all the voltage goes goes the new rectifier/regulator. The other reason behind splicing the jumper harness into the stock electrical harness is so that the stock handle bar control switch can see DC power.
BD hid conversion is a proven high quality kit. The ebay/cheap kits are lower quality ballast and bulbs. Not a matter of if it will quit working but when? Usually when you need it the most.
