kx250f shim stack setup
have a 2010 kx250f, looking to reshim it since my buddies kx450f with mb1 suspension is way better. i dont want to do THAT much taking apart and adjusting since oil is expensive and doing forks its time consuming. anybody have a basis i can go off of? im 148lbs in clothes, skill is nov/int. the bottoming seems decent so i suppose i have to do more work with the mid valve
you want a freebie ? we don't really do that on this site, you have to post up what you have and what you want , then it's up to you to make some effort to think about what you want to change , and we suggest things to help
first u need a softer spring. after u try that then i would copy the valving from a 2012. that rear shock works great for a stock shock.
i wasnt expecting anything close to perfect. simply a basis to go off of
Welcome to the site!
You do have a basis to go off of, its your stock setting. Its what you have already. Thats what mog is saying. Dive in and post up your stack and ask questions. Or you might a be good candidate for the Smart Performance DIY kit! You get the shims, the fluid and a build sheet to go off of. There are many reviews out there.
jw
actually me and the dogger have done lots of adjustments, documenting, adjusting with my forks. we got them working real good. heres the stack that pro circuit had in it before hand when it rode terribly
Springs: .42kg
Oil Height: 345cc
Comp:16
Reb:18
National Springs Tubes
Pressure Springs: OEM
Mid-Valve (Float: .20mm)
5-20x.10
2-17x.10
1-13x.10
1-09x.25
3-11x.15
Reb:
2-20x.20
1-18x.10
1-12x.10(x-over)
1-16x.10
1-14x.10
1-13x.10
1-11x.10
1-10x.10
1-09x.10 (clamp)
BaseValve:
2-31x.10
5-30x.10
1-29x.10
1-28x.10
1-26x.10
1-24x.10
1-23x.10
1-22x.10
1-21x.10
1-19x.10
1-18x.10
1-17x.10
1-16x.10
2-15x.15
1-16x.30
LSV:
1-16x.10
1-15x.10
1-14x.10
1-13x.10
1-12x.10
1-11x.10
1-10x.10
1-09x.30
but hey, my forks are toast now anyways. i pulled them apart and found a black hole of terrorism. check it out
http://www.thumpertalk.com/forum/showthread.php?t=1023111&highlight=
