xr 600 lacks power, dont know what to do.
Hi all
hope I can get some help here for my '92 xr 600.
I think I need to tell the whole story so here goes:
I've bought my xr with a defect engine.
When I got it home and cracked it open, I discovered that one of the exhaust valve seats had been eaten by the engine, and had bent the valve too.
I bought 1 new exhaust valve, and took the head to a specialist who installed a new seat, and re-cut all the seats and valves.
The piston didnt seem too bad so I just honed the cylinder and reused the old piston.
After assembly it was running really lean, and I started to suspect false air getting in. After narrowing it down, i figured it was the valve guides, because I had seen some play when installing the valves.
I took it apart again and installed new OEM valve guides, and stem seals and reground the valves.
After reassembly the bike ran 500m and bent the other exhaust valve. I found the reason to be a wrongly reamed valve guide, so I bought a new valve and guide and this time installed it correctly.
Now the bike is running, but it really lacks power. I have no reference to how it was driving before.
I dont know what to do now, I really could use some help.
Here are some specs:
Orginal Carb with
160 main
68 pilot
ABP racing exhaust with loud silencer
K&N filter, no snorkel.
it seems that its mostly lacking bottom end power, doesnt lift the front wheel at all.
thanks
- Karlo
How much compression do you have? I would have replaced the rings at the very least after honing the piston. Get us a compression reading, Plug wire off, throttle wide open and three kicks.
thanks for the input
It feels like it has good compression when im kicking. But i will try and get a hand on a compression tester, to get some numbers on it.
I was thinking that if its not compression maybe it could be a worn camshaft ?
or could the bending of the valves have caused stretching of the camchain ?
1.) It feels like it has good compression when im kicking. But i will try and get a hand on a compression tester, to get some numbers on it.
2.) I was thinking that if its not compression maybe it could be a worn camshaft ?
1.) A stock cam with the automatic decompressor will only produce around 90-100psi(~6bar) of compression in a normal engine.
2.) Other way around: a stretched cam chain will tend to produce bent exhaust valves.
At the very least it appears that your jetting could use some attention. The 68 pilot is really big; a 62-65 would probably clean up the lower throttle fueling. The 160 main is also on the small side. I would try a 162 and see how it responds.
I have now changed the pilot jet to 62, but it didnt change anything.
I have also done a compression test, with the auto decompressor active I got a reading of ~ 3 bar/43.5 Psi
Without the auto decompressor I got ~ 7 bar / 101.5 Psi
Seems quite low on compression ?
I have just received a new overbore piston, so im already looking in to a rebore. Something I should do while I have the engine open besides new piston, rebore and a new camchain ?
- thanks
