Brake fluid and front brake surge
Anyone running motorsport dot 4 instead of 5.1 in their bike? Many of the motorsport automotive Dot 3 or 4s have higher boiling points than the 5.1 fluid??
I have run ATE super blue in my car for years with good results.. (ATE Super Blue Racing DOT 4 brake fluid has a 536F dry / 396F wet boiling point)
On another note I have noticed a rather large pulse or surge when on the front brake... Almost feels like it grabs much harder on one side of the rotor than the other.
Thanks
LP
If you keep your brake fluid fresh you should not have a problem with boiling.
Bleed your brakes often as the fluid is designed to absorb moisture and disipate it so you dont have boiling. Bleeding (flushing all the fluid) your brakes a couple times a year is the minimum.
Check for a bent rotor and wash down the rotor and pads with brake clean to be sure you don't have any contaminats dirtying things up.
The last time I bled the front on my '07 I used that (because I was out of whatever I usually use on the bike) Works just fine.
