clogged petcock causing jetting problems???
wondering how much a clogged petcock would effect jetting?.....bike was getting fuel but was wondering if it was not getting it like it should? this may bete dumbest post ive ever put on here
You could probably check it in less time than it took to post the question. Just yank the line off the carb, turn on the gas, and see if the fuel flows out freely. If it does not, it could be a clogged screen in your petcock (pull it out), or a clogged vent for the tank (blow through the hose).
