loud gear box noise
when putting my 2010 yz250f into gear it some times make a loud clunk noise as it engages. only some times. my geAR BOX IS STILL really smooth and doesnt seem like any thing wrong with it. is this normal or not?
How long do you go between oil changes? Also, is you chain adjustment somewhat loose? Is your chain rubbing block worn thru? I would think that a worn item in the transmission would not be intermittant.
i do 8 hour oil changes. im not very fast and dont ride sand much. the oil is still pretty clean when i take it out. ok thanks ill have a look around. its only done 34 hours. nothing should be to worn?
Most likely what you're hearing is the chain on the sprocket. Is the bike idling high when it happens? Is the clutch adjusted properly. Mine does it all the time
