Megacycle cams?
How does the quality and performance stack up with Megacycle vs. Web vs. Hotcams?
I ran some simulations with the Megacycle 108X1 cam and it seems like a good cam for mid to upper end.
What concerns me is the huge lift these cams have. Can anyone expect any spring life with this cam or do all the cam manufacturers cams have the same issues?
Has anyone been running this cam for extended periods with the same valve train?
megacycle's cam ramps are well designed and don't beat up springs / valvetrain...
the 108-x1 is a fairly top end biased cam for a stock displacement 450cc setup....
i have run them for long periods with no issues using kpmi valvespring setups...
long duration on exhaust lobe...make sure to clay check p to v...
