Will a 95 or 98 rear wheel fit my 2007 yz250f
I'm looking for another rear wheel for my 2007 yz250f paddle tire, so I dont half to keep changing the tire. I have found a 95 and another 98 YZ125 rear wheel for a good price I know they are the same size 19x1.85 but I dont know if the axle or hub would be the same. Any info would help, Thanks
Pre 99' YZ rear axle is smaller diameter.
But you might be able to use 07' bearings in a pre 99' hub.
I'll measure up the O.D. of my 98' wheel bearings for comparison to the 07' bearing.
98' YZ250 rear wheel bearings for comparison:
O.D.= 42.00mm
I.D. = 20.00mm
PivotWorks bearing kit PWRWK-Y06-421
Lists as fitting:
91-97 WR250Z
92-93 WR500Z
88-98 YZ 125 & 250
98 YZ400F
98' YZ250 rear hub for comparison:
Hub width (outside bearing surface to outside bearing surface) = 132mm
Hub width (rotor mount surface to sprocket mount surface) = 156mm
Edited by XLR8RR
After researching bearing specs at PivotWorks, it appears that the kit for your 07' 250F (PWRWK-Y08-421), uses bearings that measure 22mm x 44mm (PW part #'s ZWBE-011 & ZWBE-012), so the bearing swap is a no-go....
Best bet is find a hub from a 2k^ YZ and use PW's site to research bearing diameters.
Ok, I know a 1999 thru 2008 yz250f will work, But what year yz125 will fit my 2007 yz250f, is it the same 1999-2008 for the yz125's also???
The rear wheel bearing kit for your 07' 250F (PWRWK-Y08-421) fits all these:
Most likely, any of those hubs will work for you.
2001 - 2003 Yamaha WR 250F,
1999 - 2000 Yamaha WR 400F,
2001 - 2002 Yamaha WR 426F,
2003 Yamaha WR 450F,
1999 - 2012 Yamaha YZ 125,
1999 - 2012 Yamaha YZ 250,
2001 - 2008 Yamaha YZ 250F,
1999 Yamaha YZ 400F,
2000 - 2002 Yamaha YZ 426F,
2003 - 2008 Yamaha YZ 450F
