oil drain bolt stuck
heres the problem i have a 03 yz250f and need to change the oil but the crankcase drain bolt is stuck on there is there any other way to drain the oil or get that bolt out?
Is it rounded? What do you mean stuck? There are ways of getting rounded off bolts out. One of the easiest ways is finding a socket slightly smaller and hammering it on. Don't hammer it on too hard or you can risk cracking your case. Use some Vice-Grips. Another way is getting a cold chisel and knocking on the edge in a counter clockwise fashion. A way is by Cutting a slit down the middle of the head and using a big screwdriver. Drill a hole and using an EZ out. Or if you're not too mechanically inclined, swallow your pride and take it to a shop.
I have one of those do have to admit they are pretty handy for some rounded nuts and bolts but haven't had to use a lot of torque on it, kind of fearing those little needles flying about
Use a longer wrench (box end 6 point) on the fastener... more torque.
If the bolt is rounded, it's going to have to be replaced anyway, so slap on a set of big vise grips and give it a sharp yank.
If you can get to it with a socket, try using a manual impact and BFH on it.
If that doesn't get it, and it's rounded off use a nut buster socket and a ½" air impact.
Last resort, cut a slot in the head and go with a flat bit and the manual impact.
Do NOT drill the bolt, that's just asking for trouble
A sharp smack with a hammer will sometimes help. Just don't crack your case!
Penetrating oil can help, too.
You could also try a little heat on the aluminum around the bolt.
