Replaced Cam Chain, Put back together, pulled clutch lever & Nothing ? ?
Replaced cam chain, did primary and balancer fix, put it back together, pulled the clutch lever and there's no resistance.
What did I miss?
Thxxx.....
Got the clutch discs in incorrect sequence and hanging up on the 2 special washers that go in first.
Both good guesses. You know that 6 inch rod you stick into the center of the clutch......and it has a "cap" that goes on the outside end?
I put that cap on the "outside" of the clutch pressure disk, instead on on the inside of it.....where it goes :busted: Make sense?
Yup makes perferct sense.
