cr500 won't idle after installing new stock reeds and top-end
Hey Guys,
Is there any special attention i should give when installing a new set of stock reed valves on my old Reed cage? I noticed that in the Service manual they mentioned a "reed valve clearance", and the mentioned a "clearance: 0.2 mm".
How do I check or measure this?
After installation, i was able to start up the bike fine but I noticed that the it was very hard to get it to idle. Now it starts but then once it warms up and I let go the throttle it dies and I can't start back up. :banghead
Any advice or suggestions appreciated.
thanks,
try checking your carb settings and make shure that the carb is clean. also if you have just did a topend it may need alittle bit of breakin befor it will idle
