Airbox mod + jetting
Hey guys...so i am planning on doing the airbox mod on my 06 x. And from what i understand i will need to do re-jetting. What jetting kits will give me the best "bang for my buck"?
Thanks
I would start with one $5 main jet. Probably a 152 if you are near sea level and around 60 degrees. If it doesn't run well, you can always spend more money.
These bikes have been around long enough that there's not much secrecy surrounding the carb settings.
The best bang for your buck is to jet it yourself as leardriver suggests via jets you can get at the dealer. More air results in the need for more fuel = more power.
There is an entire jetting thread on here where people have posted what they run. There are many variations in bikes though, so you need to find one like yours that is ran at the same altitude as where you are...and in theory, same temp too.
Post up your current bike set-up, elevation, and current settings and you should get more info.
