Chain Length Question
If, with stock sprockets, the chain is 114 links long, and I decrease the size of the rear sprocket by two teeth, approximately what would I have to cut the new chain down to?
question from inexperience:bonk:
thanks
Couple would probably do the trick (114 to 112, which is the minimum you can take out). Better to take a little out twice than too much once.
I went up one tooth, so I decided to be safe and bought a 110 to replace the stock length 108. Even with the bigger rear sprocket, the extra 2 links put it to the very back of the adjustment. Cut it back to a 108, now it's at almost the very front of the adjustment. No middle ground.
Little goes a long ways. Your best bet is to put the new sprockets on and size the chain from there.
There should be an adjustment on the swing arm or rear axle to change your chain tension. Tried adjusting that?
I can switch between a few gearing combos without having to change my chain, I just adjust the chain tension any time I change a sprocket.
