Shock rebuild?
N2 pressure would be around the same as current bikes in my opinion. 145 lbs of nitrogen is pretty much standard. As for oil volume, you have to fill it with oil and then bleed out all the air so no need to measure. You will need less than 500ml, unless you spill alot in the process.
